Adaptive Family points not aligning?
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
575 Aufrufe, 10 Antworten
placed it in a mass familyplaced it in a mass familyadaptive familyadaptive familyhow do i fix this???
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
...looks like you didn't put the model line on an adaptive point workplane.
Nachricht 3 von 11
@Anonymous
How did you create the lines? Did you select two points and create a line segment from them using Through Points tool?
Nachricht 4 von 11
als Antwort auf: ToanDN
yes.....
Nachricht 5 von 11
Did you place the adaptive family in the mass by picking 3 points?
Nachricht 6 von 11
@ashwinash112 wrote:
yes.....
@Anonymous: I don't think you did. Try placing the Model Lines again using the Spline Through Points method.
Nachricht 7 von 11
als Antwort auf: barthbradley
yes i did, ut it works only for splines??? i want straight lines forming a triangle, how do i do that???
Nachricht 8 von 11
Do two points at a time then you have all straight lines.
Nachricht 9 von 11
2.JPG2a.JPGi get this error when i create a void form
Nachricht 10 von 11
Solid Form
Nachricht 11 von 11
