I need to create a corrugated wall and not had much success using a curtain wall method as I don't seem to get the profile to follow the exact length. Anyhow I have been watching this video -
which although for a spline, I thought I could use the same format with 3 lines and split them up to the required distance ( 145mm for me ), attach the profile and click repeat and it would work. But no. Firstly the profile is aligning and secondly the repeat button is greyed out.
So I attach the fil and hope that someone out there can help me please.
Thanks.
Look what I see is that you first have to make your family called Generic_Model_Wall have to be in a Generic Model Adaptive Template because it also has to have an adaptive point.
I do this:
I hope this help you
Regrads
Diana
