Adaptive component - Orientation in model
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
mairh_tsek
607 Aufrufe, 10 Antworten
Hello all,
I created an adaptive component but in the model I cannot place it in the correct direction.  Is there any trick to do it ?
A second question, when I tap ESC the adaptive component is created, is there any way to avoid it ? with ESC just to cancel the function?
Image and family below.
Thank you in advance !!
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: mairh_tsek
It's an Adaptive Component. It will adapt. Place the Adaptive Component on the correct Work Plane. You can set Work Plane before placing Adaptive Family too.
...FWIW: a named Ref. Plane can be set as a Current Work Plane.
Nachricht 3 von 11
mairh_tsek
Hello & thank you for your time
I dont have any work plane to choose, I want to follow the Model lines each time, but when I select the two point of the line (start and end point)  the adaptive component is not placed correctly
Nachricht 4 von 11
I don't know what you mean.  If you want it flipped, then just place the AP's is reverse order.  Also, there's the traditional Mirror tool.
APs placed in reverse order:
Nachricht 5 von 11
mairh_tsek
Hello, If you check the 2nd image in my first email, I cannot place the adaptive component vertical in the line (it has not the same position as in the .rfa), it is rotated
Nachricht 6 von 11
Isn't this:
the same as this:
Nachricht 7 von 11
@mairh_tsek wrote:
Hello all,
Tick Always Vertical in the family.
No.  You have to delete it and place again.
Nachricht 8 von 11
mairh_tsek
Look the transparent one, this is the adaptive component that I am trying to place like the red one.
I will try the suggestion about the Always vertical option!
Thank you!
Nachricht 9 von 11
Thank you!
Yes, that's what I've done in my screenshot. Isn't the orientation correct? Looks exactly like the one in your screenshot.
I have no idea how "Always Vertical" helps with this. It's ADAPTIVE.
Help | Adaptive Point Orientation | Autodesk
Nachricht 10 von 11
ALWAYS VERTICAL is the solution here???  I must be in an episode of the Twilight Zone. :zwinkerndes_Gesicht:
Nachricht 11 von 11
mairh_tsek
als Antwort auf: barthbradley
Yes actually it worked for me!
