Adaptive component not being placed properly when I used Dynamo?
2 ANTWORTEN 2
Nachricht 1 von 3
firas007noori
698 Aufrufe, 2 Antworten
I am trying to apply an adaptive components (pyramid) shape by using Dynamo and they sometimes work perfectly on some surfaces, and sometimes they act as they are following or being extruded toward the wrong normal?!!
This issue happens only when the adaptive component has a depth, any Idea to make them always extruded toward their own normal (center point) of each surface???
Many Thanks in advance
Firas Noori
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: firas007noori
Do they place correctly if you place one manually and repeat?
Nachricht 3 von 3
firas007noori
als Antwort auf: ToanDN
It works perfectly if I installed them manually on both straight and curved surfaces
Firas Noori
