Hey
I have a basic Detail Item that I load in for Voids, Openings, etc. etc. This is great for regular square areas as it can be stretched.
However, how could I make this to stretch in more irregular shapes by stretching each corner?
Gelöst! Gehe zur Lösung
Gelöst von PavelAnd. Gehe zur Lösung
As you already said: Use Adaptive Points Family...as shown in my screencast:
https://knowledge.autodesk.com/community/screencast/b72192c3-73e0-46b1-a00f-4fb11849d58b
Constantin Stroescu
Thank you both. Although I was aware of this ability, the problem is that this would be visible in the model as it is a modeled element. My aim was to create it as a Detail Item so it is only view specific. I should have explained this in the OP.
@PavelAnd Perfect. That is exactly what I am looking for. I appreciate you sharing. I will look at reverse engineering it to see how you made it, and maybe add some visibility controls to turn on/off the perimeter lines.
@martijn_pater Yes I am aware of that process, but I wanted to aoid having to use other tools/settings for it.
