Is there any way to get like practice tests for the ACP exams?.
Thanks.
Thanks.
hi, you can access 'prepare for the exam" and take autodesk courses, there are test simulations and exercises. LINK:
https://www.autodesk.com/certification/all-certifications/revit-architectural-design-professional
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Hello Vitorbortoncello,
Thanks for your answer, I found only one test "the where you stand test", correct me please if I am wrong, it is the only test?
Yes it is the only test, you take the same test at the beginning and at the end of the course. There are exercises and quiz at the end of every lesson too
