Achieving curtain walling system with overlapping panels + openings
buzzytrent
Message 1 of 21
buzzytrent
I am trying to use a curtain walling system to replicate some horizontal cladding panels that have a 150mm lapping vertical joint. In the below example I have used multiple systems and disallowed joints then manually overlapped them. This works but I cannot easily create openings that span across multiple systems. Next step is custom panel.
I would prefer to use curtain grids to create the lap. I have use a custom curtain panel with an 75mm offset on each end which works really well. Until....you need openings, then Revit says no.
How can I create a system that has overlapping vertical joints, can accept openings and preferably be used for walls and roof type scenarios?
Best.
Replies (20)
Message 21 of 21
azad.Nanva
@buzzytrent wrote:
do you need somthing like this ?
