How can I create an elevation looking away from proposed works towards a neighbor, accurately showing the proposed works shadow on the neighbor?
To create an elevation that accurately shows the proposed works' shadow on a neighboring property in Revit, you can follow these steps:
I've followed similar steps within Revit. I am seeking a solution innate within Revit, without add-on.
It seems a reasonable expectation for Revit to cast accurate shadows both in perspective and orthogonal.
In this instance, it seems like Revit's limitation is that doesn't not cast shadows from objects behind the camera.
