I'm trying to make a loft area for bed, so I make a new <LEVEL> and make <FLOOR>.
The problem is
(1) I cannot access or click on these loft slabs in floor plan. I tried to adjust <VIEW RANGE>,<BOTTOM: LEVEL 0 TO TOP: LOFT>, it can be view through <UNDERLAY>, but I wanna modify it through floor plans, it is unaccessible.
(2) see photo 3
phto 1 ;Loft area in section
photo 2: in floor plan view cannot click on the loft floor slab, cannot edit .
photo 3: when applying VG to floors, the floor slab for loft is not counted in it.
ANyone could clarify how to do a loft properly in revit that would be better.
TQ
To edit the underlay elements in the floor plan, activate the selection for underlay elements in the status bar or from the Select panel dropdown in the ribbon (Refer the screengrabs attached below)
So, to select and edit the loft floor slab, activate the selection for the underlay elements and then try selecting the loft slab.
Then later, you can again deactivate the selection.
Hope this helps you!
