Accessing built-in parameter of nested family
6 ANTWORTEN 6
Nachricht 1 von 7
560 Aufrufe, 6 Antworten
I need to access (read) a parameter in a nested family (Height of a structural beam) to set the position of this beam in a host family (composite beam).
Height and other parameters I need are built-in, I cant make then instances. I could create in shared family a instance parameter (_height) and set it by formula (_height= Height) but I dont know how to use a formula setted parameter of the nested family to compute a parameter in host family.
I also created shared parameters in nested family, and set then by functions, but I also dont know how to access then in the host family.
Any Ideas??
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
no can do.  but neat trick if you can.  following...
Nachricht 3 von 7
It could have been done with shared families should they are not structural framing.  Anyhow, it is a better practice to create composite structural system in the project environment unless they can be done as a truss.
Nachricht 4 von 7
als Antwort auf: ToanDN
The system is only two beans welded together, and they could be used as columns too. I think structural trusses or just place two beams in project are not the better way.
Nachricht 5 von 7
You mean two beams welded together to create a stronger bigger beam with one analytical line?
Nachricht 6 von 7
Exactly. The welding is just to keep the primitive beams together, this way, the strtuctural properties are twice the properties of the isolated beam. I want to create a family this way to do not have to enter all this information again.
Nachricht 7 von 7
als Antwort auf: barthbradley
Sorry, dont get it.
