About sections sheet
1 ANTWORT 1
Nachricht 1 von 2
info
134 Aufrufe, 1 Antwort
Hello to everyone,
i have a question. I designed a wall over a foundation long about 200 meters, and i did sections every 10 meters using a dynamo script, that export a view for every section.
My question is: there is an automatic way (using a dynamo script?) to create sheets with a certain number of the created views of section from the script?
Thanks in advance
1 ANTWORT 1
Nachricht 2 von 2
ralphdenhaan
als Antwort auf: info
This is certainly possible with the use of a Dynamo Script. But since this is a custom made script, you can ask for some help on the Dynamo Forums on how to achieve that: https://forum.dynamobim.com/.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
