A4 Metric Sheet
A4 Metric Sheet
A4 Metric Sheet
Hi.
I couldn't open A4 metric sheets in Revit2021. It doesn't appear in the metric library folder. How can I find a solution to this problem, can you help?
mauricio_mssf
you’re in the imperial folder, not in the metrics, so you don’t see the A4 metric, if you installed the metric folder come back some folders to try to find the right one,
But I already attached the A4 format - metric
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
again those files cannot be opened in Revit
mauricio_mssf
i used the 2020 ones, what is your version? if it is earlier it will not do.
Try to install your library  version, see guidelines
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/I...
syman2000
See if you can open this file saved in Revit 2017
