A360 project loading fail. "FAILED TO REGENERATE..."
3 ANTWORTEN 3
Nachricht 1 von 4
steve
337 Aufrufe, 3 Antworten
Epic fail trying to load a BIM360:  this helpful disaster message displays.   I opened normally, from the BIM 360 blue icon, navigating to the BIM360 folder location where the .rvt file is located and get this message... https://drive.google.com/a/designbuildllc.com/file/d/1kCHo-wwPQwpWI7JutjzW2rQOdP-eU9Uc/view?usp=driv...
translation ... "we thought we'd throw your project in the trash"
I have tried opening with an audit.  no go.    The model displays on the  Bim360 document management page, a publish from 2 days ago.   https://drive.google.com/a/designbuildllc.com/file/d/13UlJ-SLQ6Fz-le7FtAv17tNJLmFFCe_c/view?usp=driv...
Assuming the good folks at Autodesk have indeed shredded my work, where are the backup copies stored in A360?  How can I "revert to a previous of the project"  as the Revit dog that ate my homework advises?
Other bim360 r2019.2 projects open fine.
3 ANTWORTEN 3
Nachricht 2 von 4
karibal
als Antwort auf: steve
May this article from the knowledge center help you:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
let's hope that the model is not corrupted
Nachricht 3 von 4
Kelsey.S
Hi @steve
I may be late here but are you able to open the file with an audit? Or did you already move to a "working" copy?
This link may have useful info: Recovery options for Revit cloud workshared models stored on BIM 360
Please mark any posts that help with "Accept as Solution" and thanks.
Kelsey Skaug
Autodesk Technical Support
Nachricht 4 von 4
Kelsey.S
als Antwort auf: Kelsey.S
Hi @steve,
I am following up to see if you got your questioned answered?
Please let us know.
Kelsey Skaug
