A360 Causing Revit to Crash
3 ANTWORTEN 3
Nachricht 1 von 4
broderickwhitlock
346 Aufrufe, 3 Antworten
I know that A360 was retired back in June of last year (2018).  If its still installed on a computer, and that computer is trying to sync with BIM360, would that or should that cause Revit to freeze and crash?  See attached image.
Has anyone had experience with this, and does the removal of A360 mitigate the freezing issue?
3 ANTWORTEN 3
Nachricht 2 von 4
RobDraw
als Antwort auf: broderickwhitlock
Since you don't need it, why don't you try uninstalling it to see if it improves things?
Rob
Nachricht 3 von 4
broderickwhitlock
als Antwort auf: RobDraw
Yep, thats the plan! Just seeing if anyone else has had this issue, uninstalled with no recurrence.
Nachricht 4 von 4
broderickwhitlock
@RobDraw It was a firewall proxy issue, that was blocking Revit from syncing with BIM360.
