A staircase - threads distance adjustment.
1 ANTWORT 1
Nachricht 1 von 2
Eero_Lunden
167 Aufrufe, 1 Antwort
I drew spiral staircases. I would like to keep the distance of 99 mm between threads (see autocad screenshot). How can I change the distance between treads if I have no risers?
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
BDMackey
als Antwort auf: Eero_Lunden
The height of the risers (tread spacing) is based upon the "Actual Number of Risers" value and the "Desired Stair Height" (which is a sum of  Base Level + Base Offset + Top Level + Top Offset). If you need to change the riser height then either add/subtract risers or change the height of the stair
