The attached image is the recommended stair layout for dog-leg stairs from BS8541-2 2012 (table 1.8). Hopefully attaching it here isn't in breach of any copyright!!
Anyway the challenge is simple - can you recreate a stair that looks like this in plan using Revit?
The rules are simple - you MUST use the tools as they are OOTB - so for example, no manual numbering of treads using text! (not that any of you would of course... ;o) ) Families / VG properties can be modified as required but it must be possible to recreate the process in a new file.
As Revit is the industry leading* BIM platform in the UK I expect this will be easy to achieve although I confess I'm struggling (particularly with tread numbering and the appearance of the cut mark).
first person to manage it and post the file wins a Mars bar. :o)
Cheers
K.
*based on no of active users
maybe my screencast can help you:
https://screencast.autodesk.com/Main/Details/00cc16c0-d180-44ae-9b01-f009d7f8e430
Constantin Stroescu
by mistake there were to linked screencast . So, please begin with minute 6.05
Constantin
Constantin Stroescu
Thanks Constantin, that's useful however there are a couple of issues that I'm still struggling to overcome.
1) when using a multistorey stair it isn't possible to number the treads above the first floor. Whilst I understand the logic here the requirement is to be able to number all flights.
2) If I circumnavigate the issue in item 1) by using a standard stair the the double cut mark doesn't display correctly
3) I still have no way of numbering the treads of the flight going up to the View Cut Plane so that it stops at the cut line - it always numbers everything tread / riser in the flight regardless.
Any thoughts?
Some thoughts of mine on this subject: http://revit4me.weebly.com/blog/archives/04-2015
Doing a mutisory stair-Stair by Component- can be a chalenge in Revit.
At a first sight , the method proposed by Revit - Multistory Top Level option ( Properties > Constraints) seems to be OK...but not BIM style at all. I took as an example a U shaped (two runs per level) that goes on a four levels buildig. I've made a Run Schedule wich contains informations about the number of Runs , Risers ,Treads...
Constantin Stroescu
Related to this API discussion on multistorey stair subements:
https://forums.autodesk.com/t5/revit-api-forum/multistorey-stair-subements/m-p/8349447
