A section without the sheet name
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
2151 Aufrufe, 1 Antwort
I am in need of a section head without which sheet  it is on(see the attached image). How to fix that?
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
kadmonkee
als Antwort auf: Anonymous
you need to assign the family for section tag and callout tag
select the section tag in the properties dialogue box select edit type
make sure the correct parameters are assigned in the call-out tag family
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
