A pox on autodesk
5 ANTWORTEN 5
Nachricht 1 von 6
FacebookGroupMember
293 Aufrufe, 5 Antworten
A pox on autodesk
A pox on autodesk. I lost hours of work on Revit again because they refuse to create a reliable "save" system. intermediate saves just randomly disappear (as they did for me) AND they definitely go bye-bye if the computer restarts with you leaving Revit
5 ANTWORTEN 5
Nachricht 2 von 6
Reuben Gross, thank for taking the time to write in this group. I'd love to understand the issue more and how I can help you. There are various reasons for this, such as:
-- Read/write failure to the storage media.
-- Program crashes (especially when writing data to the RVT model).
-- An add-in that modifies elements in ways not possible or desired through the normal UI.
-- Untested operations or series of operations (e.g. cancelling a synchronize, or using the Undo command after synchronizing).
Can you provide more details? Operating system, Revit version and updates?
Nachricht 3 von 6
Wendy Lim. Thanks for making the assumption that this is a computer or locally-generated issue as opposed to major engineering screwups on behalf of autodesk. I understand that the first thing they teach you in tech support school is look for errors OUTSIDE of the software. The second thing they teach you is to deny the first things so please don’t bother. I’ve been working with revit since 2008 and have had 5-6 computers in that time. This screwup has happened at each PC and at each version of revit. I’m now on 2021 waiting to migrate to 2022. You could and should have automatic save as opposed to set reminders. When you hit save it should just save. I’ve never used workshare and do not care if you’ve created this ^%{[ nightmare system for those who do. I want to hit save without worrying that I’ll go to the bathroom and lose a days work
Nachricht 4 von 6
RobDraw
als Antwort auf: FacebookGroupMember
Since this is not a problem with the program proven multiple times a day by thousands of users and it has happened to you across multiple versions and multiple computers, what's the common denominator?
Rob
Nachricht 5 von 6
syman2000
First of all I like to know whether or not you audit or fix your error message. This contributes 90% of the errors and crashes. If you cannot fix that and expect Revit to function properly without issue, then it is your own fault for not maintaining it or fix the issue at hand. It is like a car and you expect to maintain it to make it run smoothly. You don't expect software to maintain it for you when you refuse to fix the little things first. Once that little things you put off become a huge heap, no wonder you lose work as a result.
Also even if you have autosaved, it won't do you any good because Revit worksharing model can be huge and expect that to saved every 5 mins will no doubt tax on the network system. You have to properly maintain the model from error fixing to even reduce the over modeling within your project. This is where BIM manager is needed to keep the project run smoothly. If company is too cheap to do this and expect people to run straight like CAD, they are asking for issues.
Nachricht 6 von 6
RobDraw
I think you're making some assumptions that might not be true. It's impossible to ascertain the OPs working environment from such an unfounded complaint. For all we know it could be any number of things causing the saves to not happen. They might be happening and the OP doesn't know the actual location. I expect it to be something procedural as they mention walking away from a model without saving. It kinda screams some naivete. I doubt we will ever find out as these kind of posts hardly ever get followed up with any real details about the workflow and computer environment.
Rob
