Hi , Dear autodesk
I would ask about when you will update a new version for your autodesk programs software compatible with 4k laptop screen ... I face a huge problem when i bought an expensive laptop and i found his screen 4k that it's not fit with autodesk programs which it's just fit with full hd screen
I really need to know if you will update your software or surrendered to the inevitable and buy a new laptop !!
wait you to answer
Hi @amaraya,
you can just modify the resolution of the screen to better adapt it to your needs.
I have a 4K as well. I am facing some issues when I connect it to another screen with a lower resolution, but nothing that cannot be addressed by adapting the screen resolution, and not even that much.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
HI Nicola
First thank you for your replay
second
How can i do that ?
the a icons in revit & autocad appeared so so so small even when i change the size of my screen from display setting it's still small
and i just can't carry with me another full hd screen in every place i go to !!
still my Q , Will the autodesk update her programs to fit !!
Hi @amaraya,
glad to help.
You have to go on the desktop, right click - display settings - and set it to 200%. Everything will adapt to that. This is the same thing that I did.
Or you can increase it more, based on your feelings about that.
Anyway yes, I think they will work on that.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
I guess you have windows 10.
https://www.tekrevue.com/tip/windows-10-display-scaling/
https://pcmonitors.info/articles/the-4k-uhd-3840-x-2160-experience/
http://www.pcgamer.com/the-secret-problem-with-4k-display-scaling/
http://lifehacker.com/how-to-make-windows-work-better-with-super-high-resolut-1711254465
Here you are ![]()
Let me know @amaraya
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
