A fatal error has occurred. The application will be terminated
9 ANTWORTEN 9
Nachricht 1 von 10
7262 Aufrufe, 9 Antworten
During level creation, line selection (reference/ model) by only pick lines method, one error is continuously disturbing i.e. 'A fatal Error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects. Would you like to save recovery file?'. I tried several options like Graphics settings, Revit settings, Antivirus Settings even I updated my Revit 2018 software by Autodesk Desktop App, but no any solution found. Please look into this matter and give the proper solution on that.
Title renamed for clarity by @Viveka_CD
New title: A fatal error has occurred. The application will be terminated
9 ANTWORTEN 9
Nachricht 2 von 10
ennujozlagam
als Antwort auf: Anonymous
Try to reinstall the program could be some files are corrupted and see if helps. thanks
Nachricht 3 von 10
als Antwort auf: ennujozlagam
I tried this option also..but problems still pending. No solution found :stirnrunzelndes_Gesicht:
Nachricht 4 von 10
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! Smiley (fröhlich)
Please see the solutions in this article:  Error: "A fatal error has occurred. The application will be terminated." while using an Autodesk product and let me know if this helps!
If you still run into issues, please send us your journal file to test further, and submit a Customer Error Report (see Customer Error Reporting (CER)) containing an e-mail address along with a description of the workflow leading up to the crash and then log a support request with Autodesk Technical Support.
Looking forward to your reply update.
Nachricht 5 von 10
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Did you have a chance to see the recommendation in my previous post?
I look forward to hearing from you.
Nachricht 6 von 10
als Antwort auf: Viveka_CD
I checked your recent reply...According to your posted link, I don't know
My graphics card is suitable or not for Revit; But I checked NVIDIA
graphics settings as well as Revit graphics settings and I already used
Revit with and without Hardware Acceleration settings.And sorry to say
again, no change i.e. fatal error. In forum, Some people was saying check
'Audit' option during opening file and I also tried this option but no
response.
Nachricht 7 von 10
Viveka_CD
Hi @Anonymous
Please share your recent journal file for us to test further.
Let me know if you have trouble locating this.
Nachricht 8 von 10
After I create a building model without any errors and set all spaces and zones, I got this error "A fatal error has occurred. The application will be terminated", so I can share my file to solve this problem.
thanks
Nachricht 9 von 10
Viveka_CD
Hi @Anonymous
Please share the file and diagnostic data to test further.
Nachricht 10 von 10
Hi
Could you please send a privet link or folder to upload my file and share it for diagnosis.
Haider
