4th Floor walls showing on 3rd floor
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
avacath1122
403 Aufrufe, 4 Antworten
When I look at my 3rd floor plans, there is a portion that is darker and can be edited but is listed as 4th floor. I've looking in elevation to see if that was an issue but everything looks fine. I also tried the "attach top/base" and that didn't help either. I need to edit the 3rd floor walls but they're underneath the fourth floor when they shouldn't be.Screenshot (24).png
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: avacath1122
Set the view Underlay to None.
Nachricht 3 von 5
avacath1122
als Antwort auf: ToanDN
Just tried that, it didn't fix it. It must not be the underlay.
Nachricht 4 von 5
How did you create the Third Floor? Did you duplicate the Fourth Floor and name it Third Floor?
What's the Associated Level of the Third Floor?
Nachricht 5 von 5
avacath1122
als Antwort auf: barthbradley
That might've been it. Don't remember exactly, but I just deleted 3rd floor up and recreated them with the level tool and it seems to be resolved
