- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, how to make walls situated in this way: ][ (i.e. vertical walls are close together or are located side by side with no gap between them; horizontal walls are joined only with vertical walls and they make right angle - horizontal walls do not connect with each other)? I have to have four seperate right angle connections to use AGACAD program to generate studs in right way. But Revit connects the horizontal walls...
Link copied
