hi I want to get help on something I'm trying to create a family of windows with 4 adaptive point I created and combined them into separate families because the vertical and horizontal profiles are different from each other. but I have a problem how can I adapt the corner combination of vertical and horizontal profiles
Note: the angle of each window is different in the project
Yeah, it's behaving like 4-point adaptive family. Why don't you try a different approach, like Pattern-Based Curtain Panels?
...still, I would expect like issues even with that approach.
They only miter properly if the form swept a complete loop, not broken to separate pieces like what you have.
thanks for your response, but it can't sweep a full cycle because all profiles are different from each other
what I want to do here is actually add a void to the corners and make it cut according to the angle
