After I tried to do an interference check, all my 3D views are now showing as wireline.
If I try to make a new 3D view, nothing shows up, the same with my site plan.
Is there a way to ''close'' the interference check?
This a oddity I haven't heard about or seen before. All your 3Ds are actually stuck in wireframe? How did you "try" to do an interference check? Is it a 3rd party app or Revit's?
I clicked on Collaborate -> Inteference Check -> Selected some catergories.
That made my Revit view go wireframe.
And the views are also stuck, I can't select anything in that format.
Try and duplicate the view to check if the issue persists - it would seem like a graphics issue. Perhaps try to uncheck Use hardware acceleration.
The views are corrupt, we've had the same happening in our office (mainly on larger projects).
Delete the view and recreate.
If there's any V/G overrides save them first in a template.
When I recreate a 3D view, same thing happens. I only have 1 view that don't have the issue.
I can't seem to get around it.
Are you starting from scratch or copying a view?
Have you restarted your computer and/or Revit?
