3D Views Show Some Type of Wireframe
3 ANTWORTEN 3
Nachricht 1 von 4
tconantBSET3
355 Aufrufe, 3 Antworten
My Revit model suddenly started showing my orthographic 3D views as a color wireframe mode.  Is there a fix for this?  It even prints this way.  The project is on BIM360.
I tried shutting down and restarting.  I tried reloading and turning off the linked models.  The weird thing is when I switch to perspective mode there is no issue.  Only in orthographic mode.
Todd
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: tconantBSET3
3D view set to shaded or realistic displays as wireframe in Revit (autodesk.com)
...actually, looks like you are showing Rebar not obscured.
Nachricht 3 von 4
TripleM-Dev.net
Hi @tconantBSET3,
Try turning all Imports (dwg links) off.
VG overrides for view > Imported Categories > turn visibility off for each item (maybe leave the "Imports in Families" on)
This is generally caused by dwg links (or imports) with a large origin or geometry far away from the origin)
Sometimes the 3D view doesn't restore and the view needs to be recreated.
- Michel
Nachricht 4 von 4
Wrong Link posted above.  My initial guess was corrupted view - which we get from time to time. This is the Link I meant to post:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Elements-appear-in...
