Hi there,
When taking a 3D view on this particular project, it shows the lines partially, things are showing in incorrect positions and the fascia's don't show correctly. But the 3D itself is correct and fine.
I have checked Graphic Display and all the settings are correct as per out template that we always use. It is only this project that I have a problem with.
I have tried turning off hardware acceleration but no change.
Any help would be great.
You may have elements too far from the origin. Try turning off CAD link/import for the view.
