3D view
3D view
michal.luszpinski
3D view
michal.luszpinski
Recently after opening Revit, I've been having problems with 3D view. When I open a 3D view I can see through the building. Every object or walls are visible. Which is really annoying. Does anyone know how to deal with that issue?Screenshot (25).png
ennujozlagam
Try to delete the current 3D view and create a new one 3D view and see if helps. Thanks
syman2000
Check your eye & target elevation. If the value is huge, use the viewcube and click on the isometric. This will reset the view back to normal.
michal.luszpinski
Thanks, it worked.
