3d view zoom to fit not fitting
4 ANTWORTEN 4
Nachricht 1 von 5
yoiyoi
253 Aufrufe, 4 Antworten
when i use the zoom to fit command on and drawing imported from acad that i'm drawing over in revit , it only lurks in smalll left corner of the screen. how can i fix this so if fills the screen as required.
thnx
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: yoiyoi
Move the CAD closer to the Revit Internal Origin. It sounds like it's far, far away from everything else in the Project.
About the Maximum Distance Limit | Revit | Autodesk Knowledge Network
Nachricht 3 von 5
The DWG has elements too far apart. You can either fix the DWG, or create a scope box and use it to crop the 3d view.
Nachricht 4 von 5
yoiyoi
als Antwort auf: barthbradley
how do i find the revit internal origin? beyond the four arrows indicating the view directions , i don't see any  symbol indicating a 0,0,0 origin
Nachricht 5 von 5
Turn on Internal Original under Site Category in VGOs.  That symbol marks the 0,0,0 origin.  If you are using a release without that Category, you can find the IO by right clicking on the Project Base Point and selecting Move to Startup Location.
