Hi everyone,
I have to pull a rendering with a new phase (phase 2) of a building. The person who has been working on this file is out for the next two weeks, and I am unsure of what exactly I need to change for the new phase (Phase 2) to be not blue. Unsure if there is something in the Visibility/Graphics Overrides OR if it is something I need to change in the Graphic Display Options. Please note: I can't select anything in either the Visibility /Graphics Overrides or the Graphic Display Options.
I'm attaching what it looks like so you can see what I'm talking about.
Thank you!
Manage>>Phases>>Graphic Overrides
I have a feeling that the highlighted setting may be set to blue. Switch it to look like the attached screenshot
Hi Rina,
I just checked this and unfortunately it was already set to the screenshot you have attached. Any other thoughts?
Try to create a new view.
Is this building in a linked file - or are you in the same file? If it isn't a linked file then try opening a blank file and linking the building to it
