Hello !!
I got a problem in Revit that i have everything drawn in plan view but its 3D view is not showing anything. It was showing before but i dont know whether i clicked something mistakenly or what happened . Also i am using enscape for viewing model , so in enscape just the objects put from enscape library are shown but nothing else .
As i told it was fine before but i am not sure whether i clicked something mistakenly . Below are the screenshots attached.
Is it possible to share the file to investigate?
Perhaps all of these from their mesh geometry seem like Enscape elements, maybe there all belong a Model category which is switched off?
Could you send a screenshot of your VG? to see which model categories are off?
Cheers, K
Kunal Tuljaram Gaidhankar
When you Click reply, you can see this attachment icon:
Use that to navigate to the file and post it.
At best send it as a zip file.
could be several things....
could be phasing....
could be the element s are hidden
could be your VG settings....
could be 5 O'Clock somewhere
