3D View Setting
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
hliS658H
338 Aufrufe, 3 Antworten
3D View Setting
I have two questions regarding the 3D view setting
1. Is the view angle of the camera able to be adjusted to be wider so it can catch the whole wall within the short distance and if the answer is yes then how?
2. Or if the camera is put far away from the target to catch the whole wall, is there a way to see through the wall? I am not able to select the wall and hide it in 3D view
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: hliS658H
Go to the View and drag the crop boundary (e.g. make it wider).
Nachricht 3 von 4
Yes:
1. Turn on View Crop for the camera view > Select the crop to stretch, or and change Size Crop > Field of View > adjust size
2. Moot.
Nachricht 4 von 4
hliS658H
als Antwort auf: barthbradley
Silly me, that is a quick fix.
