Hello everyone
if I put a 3d view on my sheet there is a "big square" (I don't know how it's called) that is part of the 3d view.
I don't know how to get this smaller.
Look at attachment to see what I mean. In the screenshot the green circle is my 3D view, the small white square is my sheet and the big white square is the thing that needs to get smaller.
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You have a scope box 'Schacht 1' set for the view's extents, this will set the crop/crop region/section box. If you set it to none you can adjust it. edit: actually what you were looking for is not adjusting the 3d section box, but you just need to adjust the crop region in the view I think and then turn it off (or not, what you want).
