Image 1 - Weird transparency
Image 2 - Location of the project basepoint relative to bldg.
Image 3 - result when I attempt to create a 3d default view
Image 4 - Model compared to clipping box created when I make a defaut 3d view
Image 5 - Zoom in to see the modelHello,
I have been having some issues with my model not appearing when I create a 3D default view. I believe that the issue stems from the model having been moved far from the project base point. When I first started the project, I was using an autocad drawing to retrace the building layout and I started working where the drawing linked itself rather than move the files to the project base point. I have tried moving both the project base point and the survey point to see if this solves the issue however I have not had any success.
I have attached a few imaged to show what I am experiencing.
Image 1 : The appearance of the model when I am finally able to set a Section box to make it appear.
Image 2: The location of my project base point relative to a survey point that I have placed in the model.
Images 3 and 4: give you an idea of how large the Section box is relative to my model.
Image 5: Is a zoom in to my model.
I should also note that in order to set my elevations, I used the relocate project command to set the correct floor elevations. I am wondering if that may be what I did wrong. This model will eventually be geo-located when I get survey information so it is subject to be moved again.
Any help would be appreciated.
