3D View Cube Glitch and elements do not appear.
j.torres7Y7M2
j.torres7Y7M2
I've been working with an Architecutre Modelo without any issues for two weeks, and when almost finishing, the 3d view does not work.
I've tried all tricks that came to my mind including
-Opening model in other computer
-Upgrading from RVT 2021 to RVT 2022
-Creating new views.
-Deleting any dwg or cad imports
-Purge and cleaning of families.
It seems a Revit glitch. In fact, the 3d view cube appears completely rotated (see attached image).
Help please as I have a very urgent need to continue working in the project.
Have you tried right-clicking on the view cube and pressing "Go Home" ?
j.torres7Y7M2
Yes thanks, the first thing i tried
j.torres7Y7M2
Yes thanks, first thing i tried
Post your RVT here and we'll test it on our end.
...I'm thinking hardware (such as the video driver) is the culprit here - not the file or Revit.    BTW: what OS are you using? Windows 11?
j.torres7Y7M2
Hi barthbradley, Im sorry I cannot publish it here due to company policies.
As far as I've learnt it may be because I have lots of foors by points, and lots of points inside them.
Can't be a hardware problem because it did neither work in another two different PCs.
Will keep the thread updated if I find anything more.
