I wanted to create 3d text to put on the entrance of every room so when people are using vr inside the model they could know where that door/ entrance would take them. I have made this already but i have to manually type every room name. Is it possible to do this with room calculation point? I can have a schedule already that shows me where the 3d text is so room calculation point is working. i just wanted to use that functionality to automatically change the 3d text to the room name.
Thank you.
What about Room Calculation Point in Door Family + TO/FROM Room Parameters Fields in Schedules and Tags?
You can definitely link the model text to a Room's shared multi-line text parameter using Dynamo. Room Name is a text parameter so not compatible to be used for model text but Dynamo still might be able to do it with a few more steps.
HA! I think I missed this one by a long shot. You want some way for the Avatar to know what room the door opens to and you're looking to do this via a 3D "signage" Door Tag-like Family that will populate automatically on placement with the "TO ROOM: NAME". That about size it up?
Doesn't Autodesk have a VR Division? Forge? Whatever it is, maybe they have a Forum too. Just a thought. I mean, it sounds like something that would have has been addressed. Can't have Avatars accidently entering restricted areas. ![]()
Thanks for all the help.
"you want some way for the Avatar to know what room the door opens to and you're looking to do this via a 3D "signage" Door Tag-like Family that will populate automatically on placement with the "TO ROOM: NAME". That about size it up? "
Yes exactly. I use enscape for vr its super user friendly, and while the client is using the vr im on the computer making the changes he ask live on revit. This is really productive since they imedialty see the changes they ask. So im not exporting the model to another software just using enscape plug in.
I found a way...
I place the 3d text in the place i want and with room calculation point i get the room name. I made a schedule that has the room name and the description of the 3d text. Using di roots i export the schedule to excel copy room names colum to the description and import it again. Its not automatic and im sure there is a better way but for now it works and its super fast.
