3d terrain
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
anuragkhati
389 Aufrufe, 6 Antworten
3d terrain
not able to develop 3d road terrain from this autocad file in revit. Its not developing 3d terrain when i use toposurface please help me on this
6 ANTWORTEN 6
Nachricht 2 von 7
syman2000
als Antwort auf: anuragkhati
Here is the CSV file extract from the DWG. Just use topo create from import and specify point file. As for unit, the original is set to inches, but I am not sure if that is the actual unit. Just specify unit and Revit will create the topo from the CSV file.
Nachricht 3 von 7
anuragkhati
als Antwort auf: syman2000
could you please send me the Revit file? because it's not working in my case
Nachricht 4 von 7
syman2000
Here you go. The unit I use is feet. As I said before the DWG file you provided don't have proper unit. So when translate into Revit, it could be in inches, meters, feets, centimeter or whatever unit. This is why I provide the file so you import it yourself and set the unit.
Nachricht 5 von 7
anuragkhati
 its not opening , i m using REVIT 2020
Nachricht 6 von 7
syman2000
It is because I am using 2021 and you didn't tell me which version you are using. I gave you the CSV file so you import that into older version of Revit. Some of the Revit user may not have Revit 2020 since Autodesk stop supporting it.
Nachricht 7 von 7
anuragkhati
thanx
