3D Terrain Mapping directly from Google Maps using Built-In Option
Why REVIT is not yet able to pick 3D Terrains directly from "Google Maps" for site positions, topography and orientation using "Built-In Option" in Revit? Dynamo core does the stuff in a quite handy way but still that process takes a lot of time other than that if we have to for 3rd party still we stuck with compatibiltiy issues.
I found it in AMC Bridge using "CADtoEarth.Revit" but it crashes a lot. I am using REVIT 2018
You will struggle with CADtoEarth if you try to import a large site, so perhaps try a smaller site.  It's not the best, but it's the only free one that I know of.
I Know i have to use it for urban planning actually like transportation Road Network of a large area so i need to have a bigger site and i am having complications in merging two or multiple imports.. Thanyou for your help by the way:)
I've also tried PlexEarth, which I believe can import larger terrains.  I'ts also more accurate, although there is a fee to use it.
