AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
3d snappinig in revit
1 ANTWORT 1
Nachricht 1 von 2
kl51210
82 Aufrufe, 1 Antwort
Hi, in metric generic model pattern based (rvt families), I do not see the checkbox with 3d snapping like this
I only have this
Is that casued by version, or I do something wrong?
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: kl51210
@kl51210
Next to the placement picker where u select line or cruse or rectangle… there are to options, to place on workplace and to place on face … by design one supports 3d snapping the other one don’t … one restricts you to placing the point or line/curve on a ref plane/grid/level (ie: 2D) the other basically allows You to place a point/line/curve anywhere in the 3D Space in particular it snaps to 3D edges and vertices
simply switch the type of host you wish to place the element on and you will have the 3d snapping
In Foren verƶffentlichen
