3D Perpective View Problems - Geometry and Shadows
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
craig_SW
898 Aufrufe, 3 Antworten
Dear Hivemind,
My team member has a problem with a large project he is working on. The geometry and shadows in 3D Perpective View (fairly basic View Template, hidden line and shadows)
See attached image for the issue. The project survey and base point are very far from the modelling area. It was set up before I arrived and in my opinion incorrectly.
Do we think the issue is distance from these points or a graphics driver problem?
3 ANTWORTEN 3
Nachricht 2 von 4
JacobDSimpson
als Antwort auf: craig_SW
Well, how far is the 3D perspective view being taken from? If it is just a 3D perspective view then the distance of the survey point shouldn't really count for the quality of image you see, it is dependant on the view the camera is seeing it from.
It may be a graphics issue? Maybe try purging the model, make sure thin lines are switched on, and make sure there aren't any overrides in visibility graphics
Hope this helps
Nachricht 3 von 4
Viveka_CD
Hi @craig_SW
Welcome to the Autodesk Community!
  •  In your graphic display options under lighting try  to change the darkness of the shadows (Move the slider or enter a value between 0 and 100). Cast Shadows must be selected to enable this setting.
  • Please check the recommended systems and graphics hardware HERE
  • Is your hardware acceleration enabled?
Please specify the version of Revit your are using and check for updates.
Can you send a screenshot of your shadow settings?
Let me know if you were able to resolve your issue.
If my post answers your question, please click the "Accept as Solution" button.
Nachricht 4 von 4
Viveka_CD
Hi @craig_SW
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
