I am currently trying to export my model to a 3D PDF, but the exported PDF does not keep the same color properties as the Revit file. Is there a way to carry the colors to the 3D PDF?
You can also export as Image then Convert to PDF by using 3rd Party website or even you can print the exported image as PDF.
Can you post them side by side for comparison? The view you are exporting as a 3D and that which is in PDF
Otherwise, check the 3D PDF exporter settings!!
Here is the regular PDF export colors (the correct colors)
And here are the 3D pdf export colors:
