3D paving tile
10 ANTWORTEN 10
Nachricht 1 von 11
1776 Aufrufe, 10 Antworten
3D paving tile
Hey,
i want to create a heavy duty cellular paving type in 3D in our office project. i have created familiy type for the tile and its get waste of time when layering  the area. can you please help me to get rid of this problem. the tile in 3D is must. no seamless images will do the requirment. i will attach the image files below
Thank you
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
Hard to understand what you are saying. Can you elaborate further on what you are trying to do -- or not do?
Nachricht 3 von 11
als Antwort auf: barthbradley
okay. i have a car park area need to filled with the heavy duty cellualr paving. as per the image 2-1, green area is the car park. and image 01 include the 3D cellular paving block.
i need to fill car park with paving block.
i have tried to put the block one by one. its a waste of time.
is there any method to overcome this problem?
Nachricht 4 von 11
Only thing I can tell you is that I agree with you. Modeling individual paver blocks is a silly waste of time.  Why can't you just model the entire parking surface area using a floor (maybe with a surface hatch pattern that looks like pavers)  and then call it out as pavers in your CDs?
Nachricht 5 von 11
martijn_pater
3d is a must? Perhaps you could use a repeating pattern component..
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Nachricht 6 von 11
but our client need the pavers in 3D. thats the problem. he want to see
everything in 3D. is there any method to do so?
Nachricht 7 von 11
Why?
Nachricht 8 von 11
Are you saying your client wants hundreds (maybe thousands) of CMUs modeled individually?  That's what it looks like you're modeling in your first screenshot. 8x8x16 CMU Blocks. How about the cell fills? Does the client want those modeled individually as well?
Nachricht 9 von 11
you are 100% right. just like the images you sent me. but not as a invidual unit. may be as a block(number of units get together)
Nachricht 10 von 11
Seriously???
I don't think you'll have the computing power to do it, but if you must, you can do it through Divided Surfaces and Pattern-Based Curtain Panels.
You can start here and drill down to learn more about the process:
Nachricht 11 von 11
Actually i have some of the small areas with placing model by model. :Gesicht_mit_Freudentränen::Gesicht_mit_Freudentränen:
yeah my my revit file cannot rotate now.
