3D model shows blue color lines or is completely blue
2 ANTWORTEN 2
Nachricht 1 von 3
1685 Aufrufe, 2 Antworten
Hello
Does anybody know why does my Revit 3D view show blue color partly or completely in the view? Even when I scroll around and try to move in the space, the blue appears again...
I appreciate very much if someone knows any possible solution.
Anni
2 ANTWORTEN 2
Nachricht 2 von 3
JuanYusta
als Antwort auf: Anonymous
Hi @Anonymous
I see that you import a DWG File.. Maybe you have activated the Line Width, with the TL command
Sometimes the they look thicker than they are
Other option would be to check if the DWG file it's well scaled
Nachricht 3 von 3
That's the Coarse View 3D Cut Fill/Color representation.  Change Visual Style of the View to Medium or Fine.
