Hi Guys,
ive got an issue with my 3d view.
I cant hide the construction line from every slab i created... They appear in green line..
Anyone know how to hide them ? i wanna create some render without ![]()
thanks
Lines are not rendereds so you don;t have to worry.
If you still want to hide them then go to VG of a view and turn their visiblity off.
In the future, you might want to create temporary construction lines using reference lines instead of model lines. But for now, select them all and then click the Modify | Lines > Edit > Convert Lines tool on the ribbon. The will now be reference lines instead of model lines, and will not print or render by default.
Convert Lines tool converts Model lines to DETAIL lines and vice-versa.
Reference lines are different than detail lines.
