3d Logo
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
dcarlsen8GY35
4935 Aufrufe, 7 Antworten
3d Logo
Let's say I want to produce a 3d wall mountable logo - say the golden arches.... the equivalent of model text --- only a free form drawn profile and not a canned letter ?
7 ANTWORTEN 7
Nachricht 2 von 8
Avaris.
als Antwort auf: dcarlsen8GY35
I recommend this way: illustrator > explode into outline > export to dwg > load dwg in Revit > generic model extrusion with pick lines
Nachricht 3 von 8
dcarlsen8GY35
als Antwort auf: Avaris.
thanks i don't have illustrator - what's the magic wand solution Smiley (fröhlich)
Nachricht 4 von 8
Corsten.Au
Hi
Import Image in CAD..
Trace it..
Use that in Revit to Extrude..
In revit - you can use direct Raster Image if you just want to show images on wall
or any surface... restriction is, its only visible in Realistic or Render mode..
Best luck
Corsten
Building Designer
Nachricht 5 von 8
dcarlsen8GY35
als Antwort auf: Corsten.Au
thanks....sounds like 2 solutions depending on your resources
Nachricht 6 von 8
AzWoodWarrior
Use Autodesk Maya. You can make anything.
Nachricht 7 von 8
dcarlsen8GY35
als Antwort auf: AzWoodWarrior
good if it will make a valid paid in full receipt for the 3495 i'm in
Nachricht 8 von 8
AzWoodWarrior
30 day trial.
