3D curved walls from geometry
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
591 Aufrufe, 3 Antworten
I modelled this form, and want to place a wall over it, it does not work. along the way in revious stages it did work.
if I remove the subtraction geometries, it works.
is there a way to simply create a thickness to this surface? dont need it to be a wall..
Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
constantin.stroescu
als Antwort auf: Anonymous
Normally Wall by Face should work...
But , if from some reason it doesn't then you can use Dynamo with Thicken:
  • select Face > Surface Thicken , and finally turn Dynamo Geometry into Revit element
Constantin Stroescu
Nachricht 3 von 4
als Antwort auf: constantin.stroescu
Thanks @constantin.stroescu !
Sorry but I am new to Dynamo, how do I link the geometry in the revit file with Dynamo?
Nachricht 4 von 4
constantin.stroescu
Dynamo to Revit: there several ways
One of them is shown in the following screencast:
Solid from Surface-Dynamo | Revit Products 2021 | Autodesk Knowledge Network
Constantin Stroescu
