Not sure if I'm doing this right. when I start a project I bring in a snip of the recorders office sit photo. This is always oriented with north up. I then rotate the project base pint for 90 degree lines. I so this by selecting true north on the properties dialog.
I then have to move or recreate new elevation markers to algin. I cannot get the the 3d view compass to align with true north.
Any solutions. Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Maybe I misread you. Are you not seeing both the Cube and the Compass in 3D View?
You do not need to rotate project North.
- Bring in the site photo
- Rotate the photo to align with your building
- Rotate True North to align with the photo's north
