I using first time revit 2022. 3d cannot view. in Floor plan can see
Solved by jayhar. Go to Solution.
Try the default 3D button, this should bring you to your 3d environment. You can (then) find this view in project browser as {3D}.
check if there is assign view template in 3d view and set to none? check also section box if tick and adjust including crop view? thanks
Its solve, i open 3d view and see so many cad files inserted i delete all cad now its fine.
