3D animation objects being marked
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
jt046098
442 Aufrufe, 7 Antworten
when I move over objects in 3D animation they are automatically being tagged. How can i fix that?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: jt046098
COOL! I didn't know Revit could that!
Kidding. Can you post a GIF showing it happening.
...do you have an Add-On for tagging?
Nachricht 3 von 8
jt046098
Nachricht 4 von 8
I don't see tagging happening. I just see elements highlighting as the cursor passes over them.  If want to prevent that then use a selection restriction.
Nachricht 5 von 8
jt046098
Its still not working even if I switch off all the settings restrictions or turn them on.
Nachricht 6 von 8
mhiserZFHXS
It doesn't look like anything is actually being selected. It just looks like the UI is keeping things highlighted.  Does it stay highlighted indefinitely if you leave it alone for a bit after doing this? What add-ins do you have?
Nachricht 7 von 8
Turn off Hardware Acceleration.
Nachricht 8 von 8
jt046098
als Antwort auf: mhiserZFHXS
yea it kept being like that but switching off the hardware acceleration worked
