Im trying to build a family which consists of a 3 sided prism with a sloped top and standing on a flat plane.
the User shall be able to place 3 points anywhere and the prism shall be generated from following values:
The Z in point 1 should be 0
The Z in point 2 shall be half the distance between point 1 and 2
The Z in point 3 shall be half the distance between point 2 and 3.
I have tried for a couple of weeks working with all sorts of adaptive components and reporting parameters but I cant seem to make it work.
Can this be done?
Best regards
nkhv
So what am I seeing? Where does the values come from? Are they somehow derived from a formula as reporting parameters?
Is the plane defined by adaptive points?
The length between adaptive points are reporting parameters because you want the free dome to place these points anywhere. The height parameters are a formula based on the length's. You can open the Revit file attached for reverse engineering.
Sorry I didnt see the attached file on my phone.
I get it so far:
3 adaptive points are defined and are connected with ref lines.
Dimensions are placed between adapt points. The dimensions are turned into reporting
Ref points are placed on the planes of the ref lines and are dímensioned. The ref points are placed by using computed values based upon formulas.
Additional ref lines are placed between point zero and H2 and H3.
Surface from closed loops are made.
Am I right in this?
Can this family be turned into a solid?
@Anonymous wrote:
3 adaptive points are defined and are connected with ref lines: YES
Dimensions are placed between adapt points. The dimensions are turned into reporting: YES
Ref points are placed on the planes of the ref lines and are dímensioned. The ref points are placed by using computed values based upon formulas: YES
Additional ref lines are placed between point zero and H2 and H3: YES
Surface from closed loops are made.: YES
Am I right in this? YES
Can this family be turned into a solid? I haven't tried it yet.
I'm confused by the phrase "three sided prism." Geometrically, in the three dimensional world we live in, there isn't any such thing. You need at least four sides to construct a solid/mass in the universe as we know it. Or at least a solid/mass made of flat sides anyway.
But yeah, the distance of your corner points along a reference line B can be controlled with a formula based on length of reference line A. Although I'm worried that the functionality of such a construction might break when placed in a project if you set it up in such a way that a distance along the first line is controlled by the second line which isn't placed yet. Haven't tried it myself.
@Anonymous: If you've been unable to resolve this after a couple of weeks of working on it, I think it would help us to help you, if we could see what you have done so far. I mean, two weeks is a very, very long time to be working on a family such as you are describing.
@Anonymous
This one (2017) has two families: one with faces and one with solid. They work the same.
One thing, when I placed it on a slope, the vertical lines are perpendicular to the slope, not the global XY plane.
