3 flight stair - middle flight tread count
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Ian_H
207 Aufrufe, 2 Antworten
How do you modify the tread count for the middle flight of a 3 flight stair? I Googled it and according to autodesk there is a button to activate user-defined settings and you can change it in there. I can't find that button.
I am wanting to shift one tread from the middle flight to the upper flight.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Ian_H
- delete the landing
- drag the end grip (dot) to shorten the mid flight
- draw the beginning grip (dot) to lengthen the upper flight
- add landing by picking the two flights
Nachricht 3 von 3
Ian_H
als Antwort auf: ToanDN
Thanks!
